nicho
RIP
After a few minutes of normal operation, the fan on our Eberspacher starts hunting/surging (speed increases and decreases every 2/3 seconds or so). Any ideas welcome please.
Partially blocked fuel filter or low level in your main tank.
Can you get a video of the symptoms if you're still having problems?
Sorry, am I missing a joke here? It runs direct from the boats main diesel tank!Try running it on diesel instead of paraffin.
Sorry chaps, resurrecting this one again. The unit has been stripped, a broken gasket (somewhere inside) changed, fuel lines cleared, fuel filter cleaned etc. Fired up, runs fine for 8/10 minutes, then the fan starts surging as before. Engineer says no fault codes, and it could be the ECU. This costs around £400 (D4S unit ecu expensive), with no guarantee it will fix the problem. Anyone any final ideas before we go down the new ecu route? (which is evidently on back order anyway). Any further help would be appreciated. Thanks.
How old is the unit? Over a period of time the burner cokes up. It’s easy enough to dismantle the unit and clean the burner unit. This is why some people run a litre of Paraffin through to clean out the unit. However there is a part at the rear end of the burner unit that it’s not possible to physically get at. The rest of the burner can look clean. Some people try cleaning with caustic soda to shift the solid lumps of soot.
I very much doubt it’s the ecu.
Anyone you know have a D4? You could try their ecu.
