simonfraser
Hole in the existing top is too big
Wallas diesel hob has been fitted at a later stage using a 4mm plate of some odd white material that is somewhat brittle
Has a naff looking bit of allu frame around the infill
So, what material can I use ?
I can support it from below, so it does not have to be load bearing over a span
Obviously heat resistant, although the edges of the Wallas have stayed only warm to touch
I need to be able to cut an odd shape out for the Wallas to fit in
Perhaps rout the outside edge
White in color
Any suggestions ?
White in color
Any suggestions ?
