Supplier for sprayhood frame?
ash2020
7 Jun 2010
Fowey, Cornwall
I would like to make a sprayhood for my Hunter Medina. I will do all the canvas work and windows (it's what I do), but I don't know where to get the tubular frame. Any ideas? Thanks.
If Doug's solution doesn't work out, it isn't a big deal to DIY. 25mm tube can be bent round a form - I used a piece of chip board with bits of wood screwed to it, to bend the tube to shape. The end result may not have been quite as smooth a curve as a pro might have got, but any imperfections weren't noticeable, and the bits to join it aren't hard to find.
Thanks Steve. I did consider that, but thought it might kink.
We had a Hunter Medina and as they are not so large I would recommend you use a slightly smaller diameter stainless steel tube 22mm or 19mm as it will be significantly easier to bend and the shape of the canopy arches means it would easily be strong enough IMHO. To bend the tube you can rent a conduit pipe bender, however it is tricky to get the nice arch out of a a bender like this and you may have to be happy with a series of small bends. You can get a stainless steel fabricator to make the hoops to a pattern, which there are I understand some in the Falmouth area.
I recently made a Bimini for our bigger boat out of 1" stainless steel and a hired Conduit pipe bender which was just man enough. The main arch was 8 very small bends at 20 cm intervals , and 85 degree bend in the shoulders.
I found baseline marine were good for the fittings needed.
Canopy Fittings | Baseline Marine Products Ltd
Good luck with your project I would be doing the same in your shoes
