oldgit
£1,200 from Webasto or £60 with wireless remote control from fleabay.....
Pretty certain you can find something to spend the other £1140.00 on ?
You really just need to rip out every single wire and piece of electrical equipment, put it all in a skip and start again.
You’re going to end up doing that anyway, the only question is whether waste loads of time trying to patch it together before you realise you need to rip it all out and start again.
£250 is a vast underestimation for the cost of the components to rewire, add an extra nought.
Do the steering hydraulics need rebuilding ?....and the engine remote controlsOther than:
Engine (already replaced)
Heater (about to be replaced)
Electrics (almost certain to be replaced)
Headlinings (replace?)
Soft furnishings (cleanable)
Is there anything else to do?![]()
Other than:
You don’t need...Honda have a reverse gearWill you fit a back up engine
Idiot ,you back up a lorry , you go astern on a boat.You don’t need...Honda have a reverse gear
The 2.3 does notYou don’t need...Honda have a reverse gear
Just turn it around 180 degrees!The 2.3 does not
Of course….swift trawlers owners are used to that sort of thingYou get that just from moisture in the air
In all seriousness....when I come across an electrical connection that has corrosion....I don’t assume it’s been under the sea.Of course….swift trawlers owners are used to that sort of thing
Id unscrew all the linings as the ply inside will be wet. The ozone can only kill what it can reach. You dont want mould forming behind etc otherwise youll just be chasing smells for ages. 2.5k seems about right i reckon. All bilge pumps, water pump, water heater element?, nav lights and all wiring, new charger, new VSR, batteries, bus bar….all adds up fast
Pull the heater ducting too, that will get manky fast
