NormanS
Popcorn at the ready!
Seems to me there is some confusion here. A snubber just absorbs the shock in the chain as all the scope is pulled tight. The total loading is the same because the other end of the snubber is connected to the anchor. It just applies it to the anchor more gently but can still pull the anchor out. In some case it makes it easier to dislodge because you get a kinetic action taking place. In effect you end up catapulting the anchor out of the sea bed.
Of cause non of this would happen if we anchored properly in the first place. Its the chain that should hold you in position, the anchor on the end is incidental.
...you write about motoring very slowly. You may well know, but you shouldn’t run your engine at low power settings continually, or better still not at all. ... bore glazing and high wear.
Yachting Monthly!
https://www.yachtingmonthly.com/gea...31.1129475317.1571998607-845354258.1571998607
Specifically I quote
"but when talking about anchoring it is always worth bearing in mind that it is the catenary weight that holds the vessel in position"
Jonathan
To be fair, I think he means the catenary pulls the boat towards her anchor and in that sense it does hold the vessel in position. Lacking weight in the rode is why boats lying mainly to rope tend to roam over an anchorage in light weather.
"... in light weather...." I think this thread was about storms.
There is no kind way of putting it, you are mistaken
Feel free to post in whatever way suits you and I will do the same.
I'm sorry I offended. It is a watercooler conversation and everyone gets challenged. No big The OP's question was not about types of anchor, anchor testing, rope or chain. It was not about snubbers, kellets, riding sails or bridles. It was not about any of the red herrings that have been trailed, in particular it was not about storms.
Not that I mind - just don't criticise my post because it does not chime with a theme that exists only in your noggin.
