PetiteFleur
Whats the best time to start? All my charts etc are on board and not going down until late saturday so not able to sort out before I get down.
Thanks in advance.
Thanks in advance.
for Dover we leave @ HW Harwich ishWhats the best time to start? All my charts etc are on board and not going down until late saturday so not able to sort out before I get down.
Thanks in advance.
I usually work on 5 knots. I was thinking of leaving 2hrs after hw Felixstowe and taking the outside route. But am considering going thro' Foulgers Gat .
Sorry for the delay. I have just finished the 'outside' table and I wanted to double check the data.
The short answer is that that will do nicely. HW Felixstowe Pier on Sunday = 0445BST so +2 is 0645. all my tables work off HW Sheerness. Those tables suggest leaving Cliff Foot will give you:
HW Sheerness total duration of 8hrs 43 mins. at HW +1 = 8:44, HW+2 = 8:41, HW+3 = 8:42. So precious little difference but leaving at HW+3 you are loosing the tide done the North Foreland and slow passage here is balanced theoretically by good passage down the Kentish Knock. HW Sheerness on Sunday = 0538BST so you would be leaving on your schedule around HW Sheerness +1. Distance 46.25nm.
Inside route - Cliff Foot-Medusa - across the West Swin to the Barrow No 2 crossing point across the Little Sunk and then Foulger's Gat, etc = 39.07nm. Leaving HW Sheerness = 8:07 HW+2= 7:39, HW+3 = 7:39, HW +4 = 7:32. Anything after the HW+2 and the tide is not good going down the North Foreland.
This is the first outing of the outside route table and at first sight it suggests that in respect of help from the tide overall on the passage that the tide does not favour either the inside or outside route. Best average speed for the passage is 5.32kts outside, 5.31kts inside. Also at 5kts there isn't much help from the tide overall, you are generally using the the good bits of tide to offset the bad bits. So I guess it's down to how much you dislike crossing the Sunk Sand and going through Wind Farms against crossing the Sunk Gyratory and lumpy water off the Long Sand Head set against saving a little over an hour passage time.
I think that's worn the anorak out, anyone got a new one?
We've been using the inside route now the last two years and I'm a bit confused about the reference to Sunk Sand. Do you gain much by crossing it? We use Black Deep No1 as out waypoint and leaving that to starboard the ebb keeps us away from the sand. I can see it's technically a bit shorter to cross the sand but is it worth it?
We are planning to leave Britlingsea at about 7am on Sunday heading towards Ramsgate and points west. Our departure time is based upon a negotiation between the tidal requirements and 16 year old twin daughters need to be well rested.
Although time and tide waits for no man, it is expected to hang around for 16 year old girls.
Hope you get past Gosport. If not, don't forget Trans Europe at Royal Clarence.....Everyone's going west!
I'll be leaving the Orwell for Dover and points west Sunday as well.
Looks like there might be a big pile up at North Foreland![]()
Coincidentally I went from Ramsgate to Harwich on Sunday, I went through Foulgers Gat, we crossed Sunk Sands a bit too soon and got a bit concerned about depths as there seemed to be about 1.5m less than charted, there appeared to be a non charted build up on the west side just before deeper water was regained. We draw 2M and it was just before LW (although neaps) so we were probably pushing it anyway.
Can you be more specific about where you crossed - and did you mean the UKHO chart or my chartlet? Perhaps I need to get down there again.
