John_Clarke
About six years ago I started using organic acid technology coolant in my Volvo MD2020 because the container in Halfords said it only needs to be changed every 5 years. I have just read in the ‘Which antifreeze?’ thread that this can cause damage to the engine as it is not compatible with copper and brass. The heat exchanger and pump are brass and the calorifier is probably copper. I have also read on the web that it could damage gaskets and seals.
I plan to drain the coolant and flush it out a couple of times with water (running the engine until it is hot to get the thermostat to open). Then I will check the brass heat exchanger tubes for damage before refilling with traditional coolant.
Does anyone have any idea how much damage may have already been caused?
Do you have any further suggestions to minimise problems?
What symptoms of damage should I look out for?
