pjsmith
Hi All,
OK - I'm back in fix the boat mode. Spent yesterday down there and cut a big hole in the deck to get access to the otherwise inaccessible stuffing box. Been searching around the web, but can;t find the answers, so hopefully someone here in this great collective will be able to enlighten me.
Here is my stuffing box, attached to a small bulkhead, behind which is the stern tube (pictured below)
The bolts visible in the stern tube pick are not the other side of the bolts that hold the box in place. It looks like this area was perhaps re-enforced in the past, or during construction and the bolts glassed in from both sides.
I had some broken worn out engine mounts. These shook the shaft and I believe broke these 2 highlighted bolts loose. Both nuts (arrowed), and bolts when you try to turn the nuts rotate in place, so there is no way to tighten them. I assume that stuffing box should be rigidly mounted to the bulkhead? At certain RPM, it can still be seen moving a few mm side to side, though significantly better now the engine mounts are replaced. The nuts are captive, they don't come out the other side of the bulkhead, so despite me now having access, I cannot extract them or tighten them.
Grease - Lots of grease, had come out the other side of the box, behind the bulkhead. I cleaned up handfuls of it.
So, hopefully someone with more knowledge will be able to help me with these questions
How is the box attached to the tube? Is the tube threaded, or is it just a butt fit into the packing box? If grease is escaping the back of the box and the tube is threaded, perhaps it is broken? It does not leak a drop, but if screwed in, how could grease escape?
My plan, dependant on the above, was to cut off the nuts and try to rotate the stuffing box a few degrees (right? - depends on thread, if exists), drill new holes right through bulkhead and secure with new bolts. Align propshaft - job done?
Access is still a pig, but my concern is what happens when I remove those bolts. Presumably, I could pull that box forward up the shaft (and water would come in?)
Many thanks for any further advice. I really miss my boat!
