Jamesuk
Where can i find a pdf standard checklist in the event of a lightning strike?
I find that hat, spectacles, testacies works for me.Where can i find a pdf standard checklist in the event of a lightning strike?
Never wear a watch and after a few dunks in the sea I never carry a wallet on the boatI think you forgot watch and wallet!
As said lightning will give huge currents from the mast to the sea. A heavy low resistance conductor to the sea from the mast base will reduce damage to other structure. I disagree about using the shrouds as part of the conductor because stainless steel is not a good conductor. It will get hot with relatively low current ie 100 amps for small rigging wire. This will soften the wire destroying heat treatment or simply fuse the wire. An ali mast is low resistance so should take a lot of current without damage except at entry and exit points.
So a check list might start with check bilges for water ingress. damage to through hulls prop shaft and rudder fittings.
Secondly check rigging for discolouration or signs of heat. Mast at the base and internal support structure.
Check safety wires pushpit pullpit etc for signs of overheating.
Check gas and fuel metal pipes they may have been part of a current path
Check compass for errors.
Check electronics to see what has survived.
I think those in order of likely hood of damage and critical to safety. good luck olewill
