Richard10002
A couple of nights ago, the engine wouldnt start so I moved the connections to one of the starter batteries. (In addition to the thick red and black wires, there is also a thin cable with red and black - I dont know what this does, but moved it with the main cables).
Watching the Sterling Battery Monitor Domestic Bank, under the above arrangement, whilst it would show current discharge, it would not register above +0.0, even though I knew that charging was +ve i.e. nothing switched on other than battery charger on shore supply. After a day of this, the monitor showed about -45Ah.
Moving the wires back to the old battery, (and now the replacement battery), and the monitor shows +ve charging and I am guessing the batteries will be as good as full.
Clearly, attaching the cables from the engine battery to the domestic bank made this happen, but I merely wonder why - although I dont think it really matters).
Presumably, I can just press the buttons to zero the -50Ah reading when the batteries are showing a full charge .... but how many Volts is this in real life?
Cheers
Richard
Cheers
Richard
