Strange AIS data
do you mean heading? heading is fed from instruments so can go awry (if its missing it should be reported as '511' but that confuses some plotters even more). cog and sog are derived from the gps attached (used for sotdma timing) and are more likely to be correct.
The Lymington - Yarmouth ferries often appear to be going backwards on AIS, when their heading and COG are opposite to each other. This is because they are double ended and although the crew take the ensign down at one end and hoist it at the other, and at night the nav lights are switched over, the heading information into the AIS is left alone.
Wierd. I thought the sog & cog were calculated from positions and time between the positions.
Presumably the site linked takes the "heading" data and labels it "course", not appreciating the difference between the two. Heading is put into an AIS transmitter from a heading sensor such as a gyro compass, not calculated from anything else. There's a special value in the AIS protocol to indicate "not available" if you don't have such a sensor. Presumably theirs is meant to be connected, but not working.
Opencpn only shows cog on the chart, not sure if you can look at heading. Though it recognizes the NMEA sentence.
Presumably on here it´s cog data which is "course". It shows the boat going backwards.
So maybe their unit is transmitting dodgy heading data as a cog sentence.
It was going backwards live on opencpn as well. Which I´m pretty sure plots cog not heading.
i'd say its more unlikely to be an incorrect cog just because the whole point of deriving it from the gps which has to be attached was to ensure it was accurate (unlike heading, next port etc all of which are wrong far too often). i'd need to see the actual transmitted data to convince me that was the fault.
how was opencpn getting the deta? from an ais receiver or over the internet?
Nasa ais engine.
There seem to be a few 511degs in the marinetraffic "course" data, so maybe that site does use the ais heading data, but I´m close to 100% certain that opencpn uses the cog sentence.
And the live plot definitely showed the boat going backwards.
í'¨ÇÛÛþ7BCúí'¨ÇÛÛýCBCúí'¨ÇÛÛýCBCúí'¨ÇÛÛýCBCúí'(ÇÛûþcÂÆí'(ÆJ ŽA„ùí'(Ç#ó￾ûjg[í'(ÇA¯H`½Æüí'(ÇÛ¿￾gåí'(ÇKÓmjŸ￾süí'(Æ
޼j)«í'(Ç@7…coæèí'(Ç»ß}WÆüí'(Ç ÓMöëÆèí'(ÇÓ{J:óÂÇí'(ÇgvCæüí'(ÇÛÛþcgÊí'(Æ
޼j)Õí'(ÆC ® .gùí'(Æ@ ŽZeÿí'(Ç@Ó]ú;ãæüí'(ÇBÓkÒ'A#úí'(Ç%×Ûk'￾cúí'(Ç
ÓÖ'Ccúí'(Æ
￾5jÊâþí'(ÇÓ{j?wBÇ
That´s what´s coming in the com port :eek:
Enough for now, wish I´d taken a screenshot. Nasa manual says it does all class A & B ais messages.
Wondering now if i should email rnli and tell them some odd might be going on.
Best guess at the moment is a badly installed electronic heading input to the AIS. I found another YBW thread that starts off by covering the same sort question.
My first thought was based on there being some sort of orientation parameter in the targets AIS setup which had been incorrectly done but can find no evidence for that.
Cheers, I´ve left a post on the opencpn forum just to check that it´s definitely cog which is displayed by the prediction arrow. Pretty sure it is though.
Well still no idea what was going on with that boat but getting more into opencpn.
It displays both heading and cog.
http://www.cruisersforum.com/forums/f134/target-heading-and-cog-80560.html#post936225
With heading info in the nmea stream both COG and heading are displayed, if they don't coincide, in which case COG takes precedence.
And there´s a nifty plugin which records all the nmea data and can play it back afterwards.
Here´s some (what I think is) ais data recorded just now.
!AIVDM,1,1,,B,63P:gGt0SJPB>P7mU:=TbqttVh,4*3E
!AIVDM,1,1,,B,13P:V@hP10OwOcLMNGG:b?wh28Q2,0*28
!AIVDM,1,1,,B,13P:gGhP1sOwcDDMN9Gsr?wj2@QP,0*61
!AIVDM,1,1,,B,63P8a2H0000206P020,4*01
!AIVDM,1,1,,B,13P:`4hP00OwbODMN8ppgOv026hP,0*19
!AIVDM,1,1,,B,63P:gGh0SJP@>P7mU:=TbqttVh,4*20
!AIVDM,1,1,,B,63P:`4h0SJP@>P4hP9S3G=Vvl0,4*76
!AIVDM,1,1,,B,63MCPbt0SJP@>P6WKGkGMl1KD0,4*55
!AIVDM,1,1,,B,13P:gFPP4bOwn7rMN@asTwv82D0q,0*22
!AIVDM,1,1,,B,13P:gGhP1tOwc90MN9wKr?v82D0g,0*66
And a handy online decoder..
http://rl.se/aivdm
And found the boat in question.
!AIVDM,1,1,,B,13P<;WOP00wwM`2MNF:k=gw6R6it,0*51
MMSI : 235080605 Navigational status: 15 (N/A) Since navstat is 15, no further data can be shown for this message.
Now what :D
