JimC
Does anyone use this in a marine diesel? A mechanic friend speaks highly of its effectiveness in road vehicles' engines.
Jim.... if you use a good quality oil in your engine with the correct viscosity, change it regularly along with the filter there should be no reason for oil additives.
this is good advice and Forte is only used to FIX things, not as an additive for the sake of it.
oil is cheap, engine parts are not, so regular changes are key.
it's quite good at cutting oil burn and reducing bearing knock in old engines. Does a better job than just using heavy weight oil. AFAIK it is a molyibdenium? disulphide based additive. Some engine builders use it to assemble engines. Supposed to reduce friction.
Not a single engine manufacturer endorses the use of oil additives, does that not convey the message.
In USA EPA is attempting to ban the use of such products for both lubes as well as fuels.
