Storing impeller over winter
FlyingDutchman
15 Dec 2004
Amstelveen, the Netherlands
As I have only clocked up 32 hours this season, I intend to take the impeller out of the water pump, closely inspect it and, if there are no signs of wear or cracks, store it over the winter to use it again next year.
How can I store the impeller best?
Thanks!
Stork_III
6 Aug 2002
Here and There
Thanks!
Tie it to the engine battery switch, you might then remember to replace before starting engine?
Fire99
11 Oct 2001
Bangor NI
Personally i'd give it a spray of silicon lubricant. Works wonders on plastic / rubber bits. Then tuck it away somewhere.
cmedsailor
10 Sep 2007
East Med...
Silikone spray or even vaseline, put it in a plastic bag and store it in a dark place.
Though personally I never remove it. I doubt it gets dry inside there.
neale
30 May 2001
Essex Mud and Solent
It's not about drying out, it's about the vanes staying under compression in one place for months on end. This can shorten the life of the impeller and lessen its ability to do the job.
prv
29 Nov 2009
Southampton
Can't comment on silicone, but I would be very wary of using vaseline. It definitely eats some kinds of rubber.
I once made a contraption which used strips of bike inner-tube as springs, dragging across a wooden ball joint which I lubricated with vaseline. After a few days the inner-tube bits started to dissolve and fall apart. Pieces of the same tyre on a sister contraption which I didn't grease stayed fine. I cleaned the gunge off the first one and a new batch of rubbers lasted ok.
Roberto
20 Jul 2001
Lorient/Paris
sybrancaleone.blogspot.com
Is Vaseline the same as petroleum jelly ?
If so, I have read somewhere that it is not recommended with either neoprene or nitrile (usual rubbers for impellers), as I can't remember which one of the two I use silicon grease :)
FWIW
edit
see prv message above, a lot quicker
neil_s
28 Oct 2002
Chichester
I found mine last two years, anyway. Over winter they get kept in a small jar of water. The Johnson ones come with a small tube of glycerine and I find this can be made to stretch to two applications.
Neil
JimC
30 Aug 2001
Lancashire
Do they really need changing every year? I've always done so myself and now I have a box full of used impellers. They all look to be perfectly serviceable and have little or no permanent "set" to the vanes. This seems to indicate that they shouldn't suffer permanent deformation and loss of contact pressure through being left in the pump over Winter.
Fire99
11 Oct 2001
Bangor NI
Definitely be careful on what 'lubricants' you use. Conventional grease (and similar products) can make some rubbers swell. (Hence don't use on car brake calipers) Silicon is very plastic / rubber friendly.
alan_d
15 Mar 2002
Scotland
I think you (and Roberto, above) mean silicone.
Silicon is an element, widely found in nature (e.g. in sand) and used in the manufacture of semiconductors - "silicon chips".
Silicone is the common name for polysiloxanes, complex polymers used in lubricants, sealants and breast implants.
Fire99
11 Oct 2001
Bangor NI
Yes yes, no-one likes a smart-arse :D
Jim@sea
12 Feb 2010
Glasson Dock
The reason you are looking after your impeller is that as they are known to shred themselves at the most inconvenient moment. Perhaps like vehicle cam belts its not just engine hours but age related. Since I had 2 shred over a 40 year period I go a step further. Every spring when I re-commission my boat I fit a new one and keep the old one as a spare.
Its no use having an old one in the pump and a new one in the spares box. If it goes it could be dark, in a rough sea, etc. Have a new one every year and minimise the risk.
PS Get a "Speed Seal" thing it makes changing an impeller quick and you are not trying to use a screwdriver in inaccessible places.
VicS
13 Jul 2002
By the same logic what's the point of having an old one as a spare.
You need a new one as as a spare, then if do have to fit it at least you know its not likely to fail again within a short time.
Going to buy it eventually anyway, just buy it sooner.
FlyingDutchman
15 Dec 2004
Up till now, I have always renewed the impeller at the start of the season and I keep a new one as spare on board. It is just that I have always inspected the old one and can not find anything wrong with it. When I take out the old one in the spring, the vanes that have been sitting on the 'cam' are bent, but after half an hour the return to normal. As we have done so little hours this season, I intend to use it another year. Although, I agree thet the prospect of shredded vanes in the cooling system is not attactive...
