Otter
One of the boats in our clubs took on a quite lot of water a while ago. Fortunately someone noticed it was floating bit low, but this isn't obvious until there is quite a lot of water inside.
Problem was, it had been left for some time with the engine cooling water seacock open. Apparently there was a pinhole leak in a hose pipe.
All cocks closed when leaving the boat, a real pain for two of them but it has the added benefit of keeping the action smooth and doing a visual check. The exception is the engine intake because it has a huge anti-syphon loop and is thick new pipe double clipped. The toilets are Jabsco type so no way would I leave the cocks open to those things unattended! I deliberately didn't fit anti-syphon loops as I think they are the uggliest intrusion in a bathroom, I saw a picture recently of a heads with the seacocks on the bare painted hull (good practice) but with two huge anti-syphon loops - what's the point? Just close the seacocks when you've done the business. The whole anti-syphon in the heads thing seems a bit daft anyway, a Jabsco is a bit vulnerable but it's good enough if I'm actually on board.
As for the quote above - an auto bilge pump with a loud siren alarm protects against that one.
