sticky gel coat
Birdseye
9 Mar 2003
s e wales
Yes, I forgot to add the wax in styrene so whilst the gel has gone off , the surface is still tacky. Someone else is bound to have done the same thing and found a cure. What is the cure?
2Tizwoz
23 Jun 2005
Northumberland
PVA (Poly Vinyl Alcohol, not be confused with Poly Vinyl Acetate wood glue) mould release agent can be wiped, sponged or sprayed on to a wide range of pattern and mould surfaces to provide a very compatible and reliable release barrier for polyester, vinyl ester and epoxy composites.
another thin coat with wax in? or a coat of PVA glue to seal from atmosphere?
