Sticky binoculars.
Crowblack
23 Apr 2005
East Coast.
Had a pair of 7x50 Kunos bino's on the boat for some years now - probably about 14.
Their rubberised coating/cover has gone sticky - have tried to clean it off with just soapy water but no joy.
Although they are the boats second pair they have been useful and would like to keep them going.
Is it just something that happens with age and I've just got to put up with it or is there somathing more appropriate/aggressive I can use to remove the sticky layer.
Anyone know of a remedy ?
Is it just something that happens with age and I've just got to put up with it...
Unfortunately yes. Two causes - first plasticisers migrate to the surface and these are sticky, and secondly the polymerisation starts breaking down so you end up with the small unpolymerised molecule. This is caused by atmospheric oxygen and UV.
I'm sure I read it on here: a dusting of Talcum powder will sort it.
Fairly common, sadly. My boat bins succumbed to this ailment a few years ago. I tried pretty much every type of solvent known to alchemists but to no avail.
The only solution is to scrape it away with pen knife blade. Very time consuming and the result looks dreadful……but not sticky.
I’ve had to do it to an infrared temperature gauge, too.
I wonder if lighter fuel would work, I used to get the sticky residue of CD cases left behind after the price sticker was peeled off with it.
I think our Talcum Powder solution would be safer.
A forum search for "Talcum" would suggest that our suggestion has merit
It wouldn't. Once it's started the material will continue to break down. No idea why manufacturers use this stuff, stupid idea.
It's very tactile, feels like a quality product, is grippier than hard plastic and imparts some bash protection. On top of that it limits lifespan, great idea from a manufacturers point of view. I avoid it for "forever" things, but it's great on things that automatically have a limited lifespan.
Had something similar on bike handlebar grips. Surgical spirit worked pretty well.
I've had a few successes with a kitchen cleaner. It makes a point of removing grease but can't remember the name. Might be Jif power & shine or something close. I rub it in and work it onto the plastic. The top layer runs off using nails or a pad. The underlying plastic isn't sticky.
Worth a try. I'd previously tried a whole range of solvents with minimal improvement. I just wish I could remember the correct product. It is sitting in my kitchen a few thousand miles away.:D
fender cleaner and a stainless steel scrubber (as used on pots and pans etc) seemed to do the job on the rubber that went horribly sticky on our RIB. Sadly it does reappear as it seems to be degradation from UV.
Also meths is worth a try.
Thanks for the responses, have given Mistroma's suggestion a go - although it wasn't Cif Power and Shine but Cif Lemon Cream Cleanser.
Well you want it to smell nice don't you !
Just a brief test on one side as I'd got it in stock - - - can report it seems to work.
Rubbed a tiny bead with kitchen towel over a reasonably flat area - - the sticky gunge came off leaving a smooth surface behind.
Maybe the stickyness will come back but in the meantime seems to work.
Will report back if it works with the rest of it.
