Elessar
Ventilation is an issue with electric thrusters. I have some overheating problem with my bow thruster, I am planning to add a fan that will work in parallel with the thruster. If you will think about boxing solution, I believe that such a side-solution will be needed.
But I would be more concerned with a level of water ingress that a bilge pump cannot keep up with.
This thread is like banging a head against a wall.
If the bilge pump can’t keep up, Mike doesn’t have to worry about his thruster. Just his insurance policy.
Yes it would be nice to fix the leak. But that isn’t the point.
Even if he does fix it, it is a foreseeable event that he will have water in his bilge for some other reason at some time in the future.
For that reason you build a dam around the thruster. I did this to every one I fitted even though there was nothing but dust in the bilge.
Simple.
