Gordonmc
Toward the end of last season I experienced a slow leak from the sterngear of my boat.
I tracked it down to the aft-most rubber hose which attaches to the sterntube. With the boat ashore I have removed the prop and shaft and disassembled the sterngear, pictured:
The suspect hose is to the left in the picture. It was cut off the sterntube, but was not in great condition and what looks like plumbers mate suggests it has been a problem before my ownership
Questions.
First, I don't particularly like the intermediate bit of 60mm stainless tube as it doubles potential failure points. Has anyone seen a similar arrangement?
Although there is no evidence of a tortional sheer problem should I be worried?
I suspect the stuffing box is an old Vetus model. The spigot takes a water supply. The packing material appears to be nitrile or something similar and has never been a problem apart from one time a drip was cured by nipping up the nylock nuts. What is the packing material likely to be and should I replace?
The engine mounts have been replaced with R&Ds and the shaft coupling is not flexible. Should I be considering a flexible coupling, such as an R&D/Bullflex or similar.
Thanks for any comments. BTW, I have ordered new rubber stern gland hose from Norris.
Questions.
