Stern Glands - Deep Sea Seals or Traditional Type
Probably not an issue if a PSS is chosen as the seal is not made on the shaft itself but on the faces. One of the "advantages" of the design is that it can be fitted to worn shafts. Wear could however be an issue if fitting a Volvo or a Tides, depending on where the wear is on the shaft as the lip seals need to run on a clean unworn area sufficient to allow for the fore and aft movement of the shaft.
There is an O-ring beneath the rotating stainless steel collar of a PSS. According to Sod's Law this would exactly coincide with the worn groove on the shaft!
It's a while since I had my s/s collar off, but I seem to remember two 'O' rings. Also, my experience is the the amount of compression you apply to the bellows isn't hyper critical so hopefully you could get round any wear 'rings'. I suppose you could also vary the position of the bellows on the stern tube if you had enough tube sticking out to play with?
Hi Oliver, glad to see you've got the miles you hoped for.
I fitted a PSS to my R32: easy job (providing you can get the flange off the shaft) and it worked well for many years. I've not used a Volvo seal, but have heard good things about them, not least their simplicity and (relatively) fail-safe construction. That would be my first choice if I were replacing mine on the Rival. However, they're only available in a small range of sizes. These dimensions & prices from TE Norris, http://www.tnorrismarine.co.uk/sterngear.php
25mm x 42mm tube £82.80
30m x 47mm tube £98.88
1” x 1 ¾” tube £75.39
Spare tube of grease £4.00
I found (too late) Keypart much cheaper than TNorris.
Similarly, I have not taken mine off for a very long time, at least six years. As I typed it I thought to myself 'is there one O-ring or two?' but couldn't remember. I haven't seen many stern tubes where there was such a luxury but my comment was somewhat tongue in cheek anyway.
I swapped a DSS for a PSS this year as the free ends of the jubilee clips on the DSS picked up the throttle cable, twisted it round the shaft and damaged the gearbox seal. First real problem with a DSS in all the years I've had the boat although I had replaced it twice, once when I bought the boat and last year, when I did a top-end overhaul and replaced the engine mountings, but it was a big one and the PSS doesn't have the rotating clips as it uses allen screws.
Personally long distance I'd stick with the stuffing box and get a bag of ptfe packing from asap. Drip free and you can fix it yourself a thousand miles from the nearest boatyard.
If you are thinking about going the PSS route, check very carefully that you have enough space to fit it. I was going to fit one on a R32 but there was not enough space between the end of the gearbox and the deadwood to easily fit it in an uncompressed state (it would fit once in its operational, compressed state). Seemed like the most professional route to fix it would be to slide the engine forward to create some fitting space. At that point I elected to fit a Volvo which is much shorter and fitted without issue. The stern tube might be too small for the Volvo seal, I just sourced a 'spacer' of some silicone hose. Never regretted fitting the Volvo and on changing boat (to an R34) that was the first thing I fitted in place of a leaky
Halyard.
+1. But I can see that for some modern flat bottomed bilgeless glorified dinghys, even an occasional drip can be a niusance.
The Halyard seal is very good, but isn't in any way repairable.
Funny you should say that because I have a Halyard seal and have replaced the 3 internal seals 3 times - I even did it last time while the boat was afloat. or are we talking a different Halyard seal? - Mine is a big chunk of brass fitted with 2 rear seals one forward seal and a bush in the middle Gravity fed with oil.
Yes, Halyard sold two different types of seal. First the Deep Sea Seal which they dropped and is now made (in modified form) in Australia. Suspect that is the one referred to as once they fail (either the bellows or the faces) they are not repairable. They then made the type you have for a short time, but don't think it made much impression on the market against the well established competitors.
That explains it - I personally would not like to change the Halyard I have - easy to overhaul, even afloat - no need for expensive lifts or 12 hours against a wall or on a drying grid.
To add to the mix, there is now the BW shaft seal aswell. Designed I believe for blue water. No idea about them but they can be found below for reference if anyone is interested.
http://www.vectamarine.com/blue-water-shaft-seal.html
Rob
Something odd about the choice of metal for the body, 'Admiralty bronze'. This alloy is a 70/30 brass with about 1% tin, far from ideal for a submerged marine application. 70/30 brass is not normally cast, it is far more malleable than the usual 60/40 casting alloy and is mostly used for sheet and tubes.
Thank you all again for the information you have kindly bestowed. Based on such good useful information and further research I have decided and to go for the PSS. I always find it remarkable how much information there is on these subjects. With all of the links and information offered on this forum I am much better informed. I am sure there will be more questions as I come to install the new seal in Winter and I will update you all on how the process turns out.
Thank you and happy sailing for the rest of the season.
I have a PSS seal on my boat 4 years now and very happy.
There was a thread a little while ago where the OP of that thread was very unhappy and the bellows were cut into by the worm drive clips and failed (cut through the rubber at the carbon element.
I compared the pictures he posted with a spare I have and it looked to me that the bellows had been fitted the wrong way round. The part that should have fitted on the the stern tube was fitted on the carbon element. This end of the bellows is longer that the end that should fit the carbon element and thus allowed the worm drive clips to clamp too far away from the carbon inner end thus cutting into the rubber bellows. This may not have been a problem if the worm drive clips had been fitted with the full width of both clips on the carbon element spigot but due IMHO to careless fitting that bellows were damaged with potential catastrophic results.
So pls ensure the PSS seal is fitted correctly
