whiteoaks7
Moody Eclipse 33 stern gland - one big cap nut (47mm across the flats) through which the shaft runs, plus a locknut. The gland has started dripping enough to need bailing once every couple of days and I want to tighten it down a little (it's already had all the grease I can pump in there). Point is I'm a little worried about tackling the job here while I'm floating around in a foreign harbour. The nuts seem pretty well welded together and are going to need a stillson or something to shift them, so the question - what is the risk? I don't want to take any risk that might make the leak worse until I can be sure I'm near a haul-out facility. Or am I being paranoid?
