Volvo Black Jack stern gland
Independence
7 May 2007
I need to replace my stern gland and have had the Volvo Black Jack recommended to me by a marine engineer who reports he has had fewer customers with issues using this type than any other.
What's the general opinion of them by those poeple who use them or know of them
Very good solution if it fits your boat. There are 2 variants. The original Volvo branded one and ones made by Radice and Orbitrade that have the addition of an air vent and greaser which make the annual greasing easier and the air vent, which can also be used for a positive feed is useful in some applications.
What boat do you have?
I wanted to fit one to my previous boat, but there was too much wear on the prop shaft from the old gland for me to think it would seal reliably. Definitely worth checking this but, if you can, a good solution. In the end, I went with a PSS; It probably would have been cheaper to change the shaft, but I'd have had to remove either the engine or the rudder (starts with an angle grinder :eek:)
I moved the Orbitrade stern seal I fitted to our last boat forward by 8 inches, using a thickwall GRP exhaust joining tube from ASAP. Doing that ensured the new seal was sealing on a fresh bit of shaft.
It does not have to be 8 inches-1 inch would do!
I moved mine for better access, not to lose a worn spot.
A She 31b
A She 31b
Presumably that has a traditional stuffing box that will need to be removed. The Volvo type seals are limited in the range of stern tubes they will fit. You probably have a 1" shaft and the tube is 42mm. It is important to get the shaft size correct as the small (0,4mm) difference between a 25mm and 1" is critical. 25mm will not fit properly on a 1" and a 1" on a 25mm will leak.. as mentioned earlier the shaft must be clean and undamaged for the length of the seal.
If this type will not fit your stern tube as is , depending on type of tube you might be able to reduce or increase to 42mm. alternatively the Tides Marine One seal is a good alternative with a wider range of hose sizes to attach to the stern to P35-7 of the Lake catalogue shows the range of both types lakesterngear.co.uk/catalogue.pdf
I have an old PSS which has been in situ for quite a few years without any problems (until now).
I'm in the process of dismantling and have plenty of good advice at the boat yard. Your obserbvations are very useful. Thanks
In my 20yr sailing life (15yrs with volvo seal) I have had to change the standard volvo seal once. Next time I will get the Radice equivalent no question.
I ran a Volvo 25mm on a 1" shaft for over 10 years, replaced it when the gearbox was out anyway - no problems. Radice produce a 1"/42mm version so that's what is fitted now.
Good luck - the 0.4mm must have worn away over the 10 years producing rubber debris and heat. Why do you think they make both sizes if they are interchangeable? when I made the mistake (or rather my supplier delivered the wrong size) it was so tight you could barely turn the shaft. Fortunately discovered the mistake before launching.
The problem was Volvo didn't do a 1"/42mm. Others I knew had used 25mm on a 1" shaft without problems. Of course, plastic straws were available then!
If close get the shaft size right, the tube will clamp as it's not the moving bit.
When I bought my PSS, years ago, sizes were somewhat limited. There was no availability for my stern tube size but they supplied rubber spacers to make up to the next available size. I think these are no longer available but the technique could be used.
I bored and turned a bit of aluminium scaffolding tube on my lathe and epoxied the resulting thinwall spacer to the tube. Still in place, working fine 19 years later.
Because the Volvo seal was loose on the tube, but the correct size for the shaft.
