Billows
Anyone have the above combination? I am puzzled as to how the above combination would be wired.In the wiring instructions it says...
'If you currently have a split charge diode, then the three positive wires are already
there. Simply replace the split charge diode with the alternator-to-battery charger.'
If it replaces the diodes the switch set to 2 will put a short across the charger from input (alternator) to output (house battery) as happens with a simple split charge diode. Similarly switch set to 1 will put a short across the charger from input (alternator) to output (start battery). Does this mean the charger boosts only if the switch is off? What is the correct switch procedure?
