Scallywag
New Member
Hello Forumites,
I have a large amount of what I believe to be steam coming out of my exhaust. I have a Volvo Penta D2-40 engine on which the raw water is sucked through the saildrive, through a raw water filter, to the water pump on the engine, to a Vetus anti-syphon valve, then into the heat exchanger on the engine and from that into the exhaust elbow.
When the engine is at idle speed all appears OK. When in gear and under load, stream appears in the exhaust. Water comes out of the exhaust but the exhaust sound is more "tractor-like" than usual when under load.
Since the problem arose I have chemically cleaned the heat exchanger, replaced the valve in the anti-syphon valve, checked the impeller and all the connections.
I have now watched closely the water system when the engine is under load in gear. I can see air appearing from time to time in the anti-syphon loop.
1. Am I correct that there should be no air in the system at all when the engine is running?
2. Does anyone know how warm the exhaust elbow should feel? (at idle it is cold and under load it is hot but not so hot it cannot be held).
3. Is it OK to bypass the anti-syphon device (i.e. connect the water pump outlet straight into the heat exchanger) or will this cause water to be sucked back into the engine? I would only does this as a test in the marina when there is no risk the exhaust outlet can be below the water to eliminate the anti-syphon device as the problem.
4. Any other things to check/ideas?
