Just got a boat. Stays are too slack. Bottle screws fully tacken up. Now, Norsemen terminals (on 4mm wire) Are they any good? Or... I have 1 forestay and two rear stays. The rear stays are slack. I think the forestay is tight enough believe it or not. If I want to be cheap about it, can I just put a horizontal piece of rope across the two rear stays, pulling them closer together?!
The side stays (from the spreaders) are slack a bit too, could I pull them together if the tightening rope was forward of the mast so it didn't interfere with the main sail? Or am I just off my rocker? 20 foot boat, family cruising. Thanks. When I say slack, that's not right, I mean they are not as pole rigid as some other boats. When I shake the mast, it feels pretty good, but if you climb aboard the boat and hang onto the mentioned stays, they 'give' a fair bit.
