Starting the new season
Admin
10 Jul 2009
Hi everyone,
With the weather improving, I just wondered if you had any tips for starting the new season?
Thanks,
Isobel
YBW.com
William_H
28 Jul 2003
West Australia
Start with a boat fully fixed after last season with all the little nagging problems fixed. Set out with hope and optimism for a lot of good sailing. Just do it.
Mean while here in the antibides weather is getting cooler and I must slap some paint on the trailer in anticipation of winter lay up at home. (ready for yet another season in September.) good sailing for the new season olewill
Lucky Duck
9 Jun 2009
Another top tip, if you have removed the log impeller to allow the dehumidifier to drain while on the hardstanding - don't forget to put it back in before you launch.
Isobel
19 Sep 2013
YBW.com
Hi everyone,
Thanks for the tips you've given me so far, interesting reading.
If you have anymore, please send them over!
Isobel
YBW.com
lustyd
27 Jul 2010
Make sure the boat is actually in the water for the start of the season - there were still loads of boats in the car park when we returned from our weekend sailing with sun burned faces :D
On a more serious note:
Following the recent winds, check any halyards which were left up, they may have chafed while beating in the gales.
Again following the storms, check all fittings to ensure they are tight. Shackles and bolts may have worked loose with the movement over the winter and you don't want to be sailing when you find out.
Look up the mast - my wind indicator flew off in the storms.
Watch your depth gauge - the storms have moved the seabed, sometimes drastically so charts should not be relied upon until this settles down and new soundings are recorded.
Wear sunscreen - this weekend was brutal out on the water :D
prv
29 Nov 2009
Southampton
+1 - being hit on the head by the shackle falling from my peak halyard block was an unpleasant surprise a few years ago :)
Blueboatman
10 Jul 2005
Ahem. So long as you weren't then grabbed by the throat by the other one.
( It's ok, I wus just leaving anyway, someone said there's green Guinness to be drinking today.)
TonyBuckley
15 May 2006
Boat is in Brighton Marina
www.icloud.com
Put the sails back on!
I did genny yesterday and it was a b***** going up despite plenty of silicon spray.
And then... I sat down to read the manual (furlex) and apparently I have put the sail in the wrong groove. I really can't see it making any difference and I am stubbornly refusing to drop it and start all over again unless someone can tell me why I should :).
