sharpness
I know this might seem like a really stupid question, but if you start the engines from the lower helm (so key is left in position 1) , would i cause damage to the engine instrumentation or alternators etc by then switching the engines off from the flybridge.
Reason i ask, i would normally start the engines from the lower helm, monitor gauges and quick check in engine bay, then usually helm from the flybridge - but if i needed to switch engines off i would currently return to the lower helm, not sure if this is the correct thing to do, or if its fine to switch off from the flybridge even though the engines were started from the lower helm.
(Boat is a fairline sedan 36 with volvo instrumentation panels).
As usual, all replies appreciated.
