jamie N
My single cylinder, 10hp diesel engine starts OK, which is good. It doesn't have glow plugs, but does have a decompression lever.
My starting procedure is to use the 'fuel bulb' to pump fuel into all areas of the system, then pull the decompressor, set throttle to max and press the engine start button. Let the engine turn 10-15 revolutions, then release the decompression lever. The engine has started 'pretty much' immediately each time, before I then close the revs down to a stable tickover,
Given that the temperature has been hovering close(ish) to zero for much of the time, I'm quite happy with this.
I give the engine the initial decompressed revolutions to get the fuel flowing, and to get the oil circulated, as well as allowing the starter motor to get up to speed.
The engine's 30-40 years old, and in most ways as traditional an item as can be had, with nothing that'd surprise any of us.
Is my starting procedure fairly standard stuff for other similar engines, and are glow plugs an advantage, or a complication?
