Starter solenoid connections for outboard
tony1969
Active Member
29 May 2020
Hello
Just managed to resize my photo so I. can now upload it
So my dad and I are renovating a small fishing boat ,we are now working on the electrical items
We plan to install new batteries ,wiring ,fuse board ,lights , etc
The boat came with only one battery to crank the engine and a push button start
We are starting with the outboard it's a 55 hp Johnson 1987
In our haste to remove the battery wire we forgot to take photos or mark where the cables went
In the photo you can see the starter solenoid
The small brown wire connects to the push start button with another negative wire
My question is does the 12v positive from the battery go to the top or the bottom nut on the starter solenoid
Then I assume the positive goes on the other nut to the starter motor
And the 12v negative goes direct to the starter motor casing fixing bolt
Thank you Tony
Thank you
The small brown wire which comes from the starter is a positive to the push start button this obviously needs a live feed from somewhere
I assumed I needed to connect the positive from battery to same side as brown wire ?
So if I connect the positive feed from the battery to either posts it will also give power to the brown wire ?
Thanks Tony
Eh, no, you need to provide a switched +ve to the brown wire to activate the solenoid
that will then close the switch inside the black box and provide a +ve connection from the battery to the starter motor by connecting whatever you have wired up to the two big nuts at the top
the thicker black wire out of the side should provide an earth for the switch that activates the solenoid
thank you
On the original cable for the push start button there was spade connection brown which obviously goes to the brown spade connection on the starter and a black wire with a ring connection this must then go on the same side as battery positive for the starter ?
So live feed from positive battery cable on starter going to push start switch then going to brown spade connection on starter
Thanks Tony
On the original cable for the push start button there was spade connection brown which obviously goes to the brown spade connection on the starter and a black wire with a ring connection this must then go on the same side as battery positive for the starter ? - No, black needs to be -ve
no, see below
Brown is a +ve supply as a switch wire to the solenoid
black wire is -ve for the circuit inside the solenoid needs to go to a -ve busbar
+ve from battery to one of the big terminals
other big terminal to the +ve of the starter
the starter is v likely getting its -ve by virtue of being bolted to the engine
Thank you again for the help
I have made a quick drawing is this correct ?
This is just for cranking engine
Tony
Thank you kindly for the help and continued support ?
That drawing was the original set up when my dad purchased the boat ,the previous owner also used the wrong colour wire from battery live on solenoid to push starter button which was black which got me confused , anyway
So it would be best to use a live feed from a designated fuse on the fuse board ( which I don't have yet ) to the push starter button then to the solenoid brown spade connection
Thanks Again Tony
That's probably why the previous owner wired it that way as there is no fuse board just cranking battery
And Push button start and kill switch
My dad plans to install new fuse board ,lights etc
