Jonny20212021
New Member
Hi!
Ok, so coming back after winter I started the boat and she fired up no problem, then wouldn't start, I kept trying and believe I burnt the starter motor out. The original issue I believe is down to the spark plugs.
Anyway, purchased a NEW replacement starter motor and it cranks very slow not enough to fire up (or at least test to see if my original diagnosis of spark plugs was right) it cranks as if it can't be bothered or something is holding it back.
I've done the following...
Cleaned all points.
Tried a brand new battery (from a 4*4) the existing one showed as weak under load test.
Voltage drop test good
Resistance test good
Jumped the starter with jump leads
Made its own dedicated earth with a jumper cable
12.6v to the starter
Taken the aux belt off disconnecting the power steering and alternator.
Taken the sparks out, can easily spin by hand but still getting the same result when testing the starter.
Is there anything else that I may of missed before I try sending the starter back.
One thing to note is the starter was smoking when I first installed it. Then smoked again tonight when I connected 2x batteries in parallel
It was turning over fine on the old starter motor (untill I burnt it out)
This is the starter motor I purchased New Marine Starter Motor for 4 Cylinder 2.5, 3.0L with 12 3/4" Flywheel
For a 1996 Mercruiser 3.0l serial number F794151 they look exactly the same and says it matches so hopefully I've brought the right one.
ANY help or suggestions are greatly recieved
Thank you!
Cleaned all points.
Thank you!
