jonathanhsm
Anyone know how to remove the starter motor from a Perkins Perama M20 – which is pretty much identical to a Volvo MD2020 ?
I can see a 6mm hex bolt on the rear … and at least one standard bolt coming from the front.
I want to take it off and test it because I may need to replace it. At the moment there is a faint clunk when turning the ignition which comes from the relay which starter shares with glo-plugs.
Batteries are fine and I’ve buffed up all the connections so assuming the starter or solenoid has gone bad.
Any advice much appreciated !
