pvb
A friend's 1959 Rover P4 had a press-button start. My 1962 Morris Minor had a pull-button start.
And of course the original 1959 Mini had a button on the floor to start the engine.
I had a mini with a push button start. IT ALSO HAD AN IGNITION KEY IIRC. IDK about your examples. Either way it is irrelevant. It is barely significantly harder to unlawfully start a yacht fitted with key ignition than one with a button.A friend's 1959 Rover P4 had a press-button start. My 1962 Morris Minor had a pull-button start.
[pedant] It wasn't really a button, it was the starter solenoid. [/pedant]
I guess you're not old enough to remember the first Mini, Paul, but it had a floor-mounted starter switch, not a solenoid, just a simple on/off push switch.
http://www.minispares.com/product/Classic/17H5260.aspx
Just when you need a pedant, two come along at the same time![]()
The issue with method of starting is reliability IMO. Theft is not really an issue (at least to me & I'm the op)
Thus far it appears that:
The starter key switch system is a bit cheaper and the electrics are simpler. Partly through that simplicity and partly in the switch construction are points in its favour.
The push button system is obviously more complex therefore potentially less robust, but more convenient.
I'm favouring the push button, for convenience. Also if I've designed and built the system, I'll know it inside out and that would help mitigate the complexity.
Two pedants coming along: is that what’s meant by bipedal locomotion?
Thanks for your valuable advice, by the way.
