Bedminsterbob
New Member
I have a near full tank of 3 year old fuel, is it best to keep running the engine on it till the tank is empty or keep topping it up with fresh fuel every time I can get a gallon or so in it.
How would you go about getting rid of that much fuelBest to ditch it. It will probably have lost most of its octane rating, and therefore will cause the engine to knock, if it starts at all. It really isn't worth the risk.
The tank is 290ltr
Oh, if the engine is running well I think I would use it up as quickly as possible, refilling when maybe 1/3 left.
If it was stored in cool conditions, it could still be ok.
Properly disposing of large amounts of duff petrol is difficult,
I think that's what I will have to try, I don't know if adding a Octain booster would help
200lts + of Petrol?? They will love you for that!You are placing your engine and bank account under unnecessary stress. Decant it off and dispose into the marina oil tank.
Don't take my word, but do a bit of googling on petrol/gasoline and performance over time. I'm guessing your car engine is quite old? Land Rover V8? Low compression, and unstressed?And on another note. I run a dual fuel LPG vehicle. Very occasionally I switch it to petrol just to make sure everything is working and it does, perfectly. I have not added petrol in the tank for at least five years, where is the problem?
Sorry, bad petrol WILL trash an engine very quickly when you get knock. Marine engines run at much higher duty cycles than automotive, and therefore any knock will quickly trash a piston. Does the OP need to run this risk for £200 of old petrol?It's old, but I grew out of traffic light competition in my early 20's. Point is that old petrol is not going to trash an engine. Might not generate the 100% you need to create a truly spectacular wake shot but it will still run the engine. Top up, refresh but there is no need to dump it in the oil waste.
