Stainless steel tube fittings.
Appleyard
23 Oct 2004
UK
Hello all. I am looking for 2 Stainless straight couplings..(as used for making a bimini etc) 22 mm i/d .Plenty of elbows,T pieces available but straights seem to be difficult to obtain. Have tried Sea Screw ,.Anyone know where I can get above items? Nothing else will do for this particular job. Ta
Appleyard
23 Oct 2004
UK
Thanks for the hint Damo,but I am not using them to join tubing. It would take too long to explain what I am using them for,but only this type of fitting will do for this particular job. Thanks anyway.
tazzle
9 Sep 2005
al pub is in Dean St, but live sarf
Try Makefast - I got a couple of bits from them last year, but remember that their min order and postage charges were a bit high. Seascrew sell a few of their bits, I think, so worth a call to Seascrew to see if they can get them for you more cheaply if you have the parts numbers.
Appleyard
23 Oct 2004
UK
Thanks Raedwald ...Had a look... interesting site and lots of good stuff,but no plain fittings.
Appleyard
23 Oct 2004
UK
' fraid not..I need a plain end-to end fitting..the type with the allen grubscrews to secure the tube. Thanks anyway.
Appleyard
23 Oct 2004
UK
Many thanks fellas for all the suggestions,however I have tried all the places mentioned..(.some good stuff though!) but have come to the conclusion that this item just is not available anywhere. I have a piece of Stainless bar kicking around so will stick it in the lathe and turn the fittings from scratch. It will not be fun. Cheers
rogerthebodger
3 Nov 2001
What I do is take a piece of tube the same O/D as the tube to join and cut a slot down the side then squeeze the tube in a vice until it fits inside the tube to be joined.
