PetiteFleur
In Aldi this afternoon and they have packs of Stainless Steel screws - 3 different packs at £3.99 each. Good selection of screws in each pack and good value.
Saw that advertised, they're A2 stainless, marine quality is usually A4 I believe (don't profess to know the difference)
300 Series—austenitic chromium-nickel alloys
Type 301—highly ductile, for formed products. Also hardens rapidly during mechanical working. Good weldability. Better wear resistance and fatigue strength than 304.
Type 302—same corrosion resistance as 304, with slightly higher strength due to added carbon.
Type 303—free machining version of 304 via addition of sulfur and phosphorus. Also referred to as "A1" in accordance with ISO 3506.
Type 304—the most common grade; the classic 18/8 (18% chromium, 8% nickel) stainless steel. Outside of the US it is commonly known as "A2 stainless steel", in accordance with ISO 3506 (not to be confused with A2 tool steel).
Type 316—the second most common grade (after 304); for food and surgical stainless steel uses; alloy addition of molybdenum prevents specific forms of corrosion. It is also known as marine grade stainless steel due to its increased resistance to chloride corrosion compared to type 304. 316 is often used for building nuclear reprocessing plants.
What providence do they have?
I find A2 OK for some jobs on board they're useful enough for all sorts of non marine jobs, number plates for example.
they're cheap.
they're cheap.
Thanks, I'll try them but if they stick to a magnet I may not use them on my boat
