petem
Lots of us use Velox in the Med.
Seems to largely stay on for the year and eradicates all fouling where we are.
Just to clarifyLots of us use Velox in the Med.
Yes, on my stainless steel props. Quite a few of us Med boaters use it (JFM, Bart, Vas to name a few).Just to clarify
You use Velox on the SS props as well as the outdrive.?
Marlin Velox Plus Propeller Antifoul 500ml Black
Thanks I’ll give that a go next yearYes, on my stainless steel props. Quite a few of us Med boaters use it (JFM, Bart, Vas to name a few).
Interesting I thought of this as I used to use an IKEA bag on our 150hp outboard that would not lift completely and that worked well. However, I can’t reach my outdrive due to the bathing platform. I currently reverse into my pontoon mooring at Cobbs Quay which is facing approximately S and not much movement of water. I wonder if I went in bow first so the stern/outdrive is facing out into the passageway between the long gangways where there is more movement of water and facing North might be better.As growth only appears when in sunshine (well it's worse when), could you not trim up and fit a prop bag to keep them out of the sunshine??
Extra Large Propeller Bag - West Wales Marine
Was the Hammerite Special metals primer the red colour? And what colour Velox on top? Was this spray or hand painted? Thanks.Anything submerged, especially near the surface where the sun will bring light and higher temperature, will foul.
If the goal is to prevent growth on propellers I can see two ways:
1: Use the boat more frequently
2: Apply antifouling
#2 brings a challenge: Get it to stay on for a full season.
Of the many products I have used (even unorthodox) over 5 decades and 7 boats, the best result has been Hammerite Special Metals primer with Velox on top.
Held up pretty well on current boat, pushing 7½ tons at 24 knots (now and then,- not all the time) ?
All painted, red primer and black Velox - as per the instructions.Was the Hammerite Special metals primer the red colour? And what colour Velox on top? Was this spray or hand painted? Thanks.
I'm on a shaft drive and my prop never sees sunlight. When I lift the boat my prop has little to no growth. A small bit of slime maybe but no weed formation. Maybe parking so the outdrives are in the shade may help?Interesting I thought of this as I used to use an IKEA bag on our 150hp outboard that would not lift completely and that worked well. However, I can’t reach my outdrive due to the bathing platform. I currently reverse into my pontoon mooring at Cobbs Quay which is facing approximately S and not much movement of water. I wonder if I went in bow first so the stern/outdrive is facing out into the passageway between the long gangways where there is more movement of water and facing North might be better.
Well it certainly won't hurt to try. Not sure you'll cure the barnacle issue, but should help to prevent the rapid weed growth.Ok so if we believe it is a sunlight problem causing the props to barnacle and foul up what about fixing a tarpaulin on bungee cords from the pontoon to my bathing platform so the sun can’t get to the props. I’m normally backed in. What do people think.
Also, a decent snorkel set up and a scrubbing brush is a worthy investment for mid season or bi monthly scrubsWell it certainly won't hurt to try. Not sure you'll cure the barnacle issue, but should help to prevent the rapid weed growth.
I've noticed more of a beard on the side of my boat that's in the sun compared to the side that's against the finger pontoon and in the shade!
Already do that in July and AugustAlso, a decent snorkel set up and a scrubbing brush is a worthy investment for mid season or bi monthly scrubs
I use industrial white scouring pads when cleaning in the water. I also do the outdrive, depth transducer and speed log wheel as well at the same time. Being a planing boat any growth on the propeller, leg etc makes a massive difference to performance and running costs. Sometimes can cut my speed down by 50% and double fuel costs which is crazy. I think semi displacement wins out here.Sounds like a plan. I have a semi-D hull and a bronze prop. It too fouls but I just pop a mask on and go down to give it a scrub. It doesn't take very long. I use a green nylon domestic scouring pad, rough enough to take the fouling off but soft enough not to harm the prop.
