Trident
If I completely encase stainless in epoxy below the waterline does this make it immune from corrosion as no oxygen can reach the metal (provided that the epoxy does not break down )
I have just drilled an exploratory hole on my rudder to check the tangs for corrosion. Although there is moisture in the rudder and omotic blisters, the 44 year old 316 stainless steel is in perfect condition. No corrosion at all
Well I said below the waterline so if chain plates are down there corrosion is probably less of an issue than drowning at that point!What is the application exactly? Will they be completely buried?
From experience, water will get into in chainplates.
I can't give you an academic response, I can only tell, you that my rudder shaft has been encased in epoxy and is corrosion free after 44 years. I do however, believe that the stainless steel is a far higher grade than that which is now sold as 316 grade. My experience with new 316 has not been goodBut does anyone know the answer to my question?
I did suffer crevice corrosion one time.If I completely encase stainless in epoxy below the waterline does this make it immune from corrosion as no oxygen can reach the metal (provided that the epoxy does not break down )
Epoxy is not impervious to O2 or water penetration. It is used to prevent osmosis as a barrier coat, but it still lets stuff through. The thicker and the more coats the better, but you won’t get hardly anything to last forever. Just look at the Roman Colosseum or the Pyramids. They are ruins and few structures have lasted longer.But does anyone know the answer to my question?
There is plenty of dissolved oxygen in seawater. Marine life exists even at tremendous depths. Corrosion occurs where differential oxygenation occurs, such as crevices and pits.Yes, if stainless steel is completely encased in epoxy and no water or oxygen can reach the metal, it should be effectively protected from corrosion. Stainless steel resists corrosion mainly due to a thin oxide layer that forms when it reacts with oxygen. Below the waterline, where oxygen levels are low, stainless can be more prone to corrosion if exposed to water directly.
I think the answer is that if you encase stainless in epoxy then some water may get through and it likely won’t have enough oxygen to prevent corrosion. Probably not a good idea as without oxygen stainless will corrodeIf I completely encase stainless in epoxy below the waterline does this make it immune from corrosion as no oxygen can reach the metal (provided that the epoxy does not break down )
