st60+ wind show negative speed
Stefan_J
29 Aug 2024
st60+ wind show negative speed ( - 5 m/s about -10 knot ) has any had this problem
i measured the voltage on the yellow cable have about +4 V average
Metalicmike
8 Apr 2023
Tenerife
Hi i have not change anything it just started with showing 0.0 in windspeed. The windvane works fine showing the correct angel
Check out the Raymarine forum, I had a quick look and others get 8V on Yellow but not knowing whether its a digital or analogue signal makes it difficult to speculate where the fault lies. Its probably going to be right at the top of the mast :rolleyes:
RAFFY
6 May 2020
Hi, my ST60+ has done this a few times in the past 10 years. In that time I have had a new masthead unit which hasn’t cured the problem (but did solve another problem). When it occurs, I perform a reset and it returns to normal operation. Worth a try maybe before buying expensive parts?
Stefan_J
29 Aug 2024
Thanks it did the trick but i had to test 4 times before i could enter the reset menu so now it's working fine.
