SSR or Part 1 help requested
dkm
26 Sep 2007
hamble
I plan to take my 11m mobo across the channel this year (first time). I'm the second owner and I have an SSR number but need to know the expiry date - does anyone know how to get this?
Also - do I need a Part 1 official number? if so where do I get it?
Thaks
absit_omen
28 Jan 2004
You do not need Pt 1. This would be an expensive and unneccessary process.
You do need Pt 3. More importantly, you need the Certificate in your name so you need to re-register. Costs about £25.00 and can be done on line on the MCA website.
Good luck.
Refueler
13 Sep 2008
Far away from hooray henrys
Thaks
The SSR number if it came with the boat is invalid as it refers to previous owner.
Go to this : SSR Reg site
and sort out to your name. The previous owner should have cancelled / surrendered the SSR certificate when he sold the boat.
There is no need to take Pt 1 ... stick with SSR and you'll be fine.
properjob
1 Jan 2005
IOW
An SSR number is allocated to a boat, therefore it remains with the boat when sold. The previous owner surrenders his certificate and the new owner applies for a new certificate in his name, the SSR number is the same.
Cariadco
19 Jan 2007
Back where I belong... Corfu
I hope the previous owner has surrendered his SSR.
If not, then you've some tough times ahead, getting the MCA to accept you're the new owner. You might be needing the help of the previous owner.
Can't blame them though.
Refueler
13 Sep 2008
NOT necessarily. It depends on time between suspension and re-application. There is no g'tee of same SSR number allocated - same sistuation as Call Sign with lapsed radio station licence.
I know this as fact as my SSR lapsed on my boat while I was away and I had to have correspondence with SSR to retain the same number. I had received a letter basically saying that having not received renewal of SSR to confirm that boat was sold, out of commission or otherwise disposed of etc. and that SSR number was therefore cancelled.
It normally would not be a problem as 99.9% of the time application is within a short period of previous owner cancelling or you renewing your SSR.
