john_morris_uk
The principle of using radials is well established and easy to understand. There's certainly no need to buy into the OTT marketing hype of the KISS sellers. There's no secret to the design and no magic involved. If you want to go down that route, just get some lengths of wire or varying length (I can suggest some figures if you want?) and lay join them all together at one end and lay them all down in the bilge of the boat.
However all the KISS system and its adherents are doing is cashing in on the poor earth systems that many boats are hampered by.
A vertical antenna's performance is DIRECTLY proportional to the effectiveness of its earth system. (Can easily be shown mathematically if you are interested.) This means that no matter how good your ATU and your insulated backstay is then you won't get good results without an effective connection to the (electrical) ground round the antenna. The ideal would be for the vertical to be suspended over a silver (or silver plated-copper) solid plane of metal in all directions. If you have that in your mind, you can see what you are trying to achieve. All KISS system does is 'pretend' to be a ground for the ATU to work against.
The good news in all this is that sea-water is a relatively good conductor of radio frequency waves (compared to bare earth!) and so connecting to the sea by direct contact or capacitive coupling is the best bet.
The problem with capacitive coupling using foil is that the average hull thickness means you will have to have a VERY large area of foil to provide anything like a low enough capacitance. I suggest that one needs to achieve something like 0.1uf to not allow the capacitance to have too large an effect on the tuning of the system. As many will know, capacitance between parallel plates 'C' in a vacuum is given as:
C = ε₀εr(A/d) in Farads
ε₀ is 8.8542e-12 F/m
εr is dielectric constant (vacuum = 1)
A and d are area of plate in m² and separation in m
which means that the capacitance is directly proportional to plate separation. The dielectric of a GRP hull may give you a slightly better figure, but the average hull thickness means that even for ten square metres of plate perfectly stuck to the hull and if the separating GRP was only 2 cm then by my calculations the capacitance would only be in the region of 0.0443 uf and that is not a large enough capacitance. It 'might be' but it won't prevent unexpected results. Mesh will NOT work as well as the deciding factor is surface area. Short connections to major metal work in direct contact with the sea is the best bet. I am not convinced by the efficacy of the sintered plate, but some have found them to be very effective so don't throw it away if you've got one. (Or if you do throw it away, throw it in my direction so I can trial it!)
For those who say that they have seen a system working brilliantly with a few metres of foil and a mesh and a few connections, then I humbly suggest that what is happening is a mixture of coupling to the seawater, with a lot of the 'earth wiring and foil' being used as a counterpoise. The lengths of wire and size of foil will have occasional dramatic effects on the efficiency of the system and its no wonder that such a system sometimes works on some boats and doesn't on others. When such a system doesn't work very well on one frequency it might be perfectly ok on others. One some frequencies you will get interaction with the RF all over the boat and in unexpected places. Remember the BEST results will be from a short efficient connection to the sea. If that means copper tape to the keel plus foil on the hull under the aft bunks then go for it.
Finally, remember that even if you have a brilliantly set up system, with an excellent 'ground connection' on the ATU, but if you happen to transmit on a frequency where there is a resonant length of wire somewhere in the boats wiring set up, you WILL induce currents in that length of wire and get very strange effects round the boat. Just remember when you try to fathom out what is going on that RF is strange stuff and doesn't behave according to the laws of DC.
