SS bow protection
mattonthesea
28 Nov 2009
Bristol
ayearatsea.co.uk
I would like to add a stainless plate to the bow to protect the grp when the anchor is stowed. But I don't know the thickness I need or how to mould it to shape.
From my schooldays I remember the technique of hammering slowly across the sheet to form a shape but I imagine that as sheet will be too tough to hand hold in place. I also imagine that the grp would object to being hit repeatedly.
Would a thickness that I can bend by hand be too thin for protection?
As it happens, I was looking for some stainless earlier in the year to do the same. I ended up doing the same as AndrewB above. Cutting and fitting a piece of white Treadmaster was quick, easy and it still looks the same even after being hit by the anchor as I was modifying the bow roller to fit an electric windlass.
I thought I'd have to buy a big piece but the local chandlery sold packs of two that were just about the right size and shape. It is even self adhesive.
What adhesive did you use?
I intend to have the anchor lie against the hull when stowed. She's a Rival 32; while I do have an extension with roller it's not great. I think the chain through the original slot is preferable.
So I wonder if treadmaster would cope with the edge of a Supreme held fairly tightly against it? Be good if it does.
Anyone tested this?
