Grumpybear
Poly cell mould killer works. Pressure washing works but may well remove the waterproofing as well.
In fact both the spray hood and the sail cover have started to develop a green tinge. Putting the sail cover through the washing machine didn't really help, but can't even try that with the spray hood. Any one got any suggestions that won't damage the original colour and might stop future growth (is it algae or mould?)
As ever any advice appreciated.
+1 for Polycell Mould Killer and a pressure washing did remove the waterproofing :-(
Incredible! I read this thread and decided to go for the Patio Magic. So 8.00pm last night I ordered some on the interweb with free delivery and it arrived at 8.45am this morning!
It's an amazing world![]()
See post #7 - pressure wash then re-proof with Fabsil Gold...
Do you think the other treatments suggested don't remove the waterproofing?
It seems that Patio Magic is a diluted solution of Benzalkonium chloride - if you're going to use a lot, it would be much cheaper to buy the base chemical and dilute it yourself if you can find a suitable supplier.
That's why I recommended Algon it is more environmentally friendly than patio magic this site gives more info http://www.algon.co.uk/index.html
I couldn't find a hazard datasheet at this site. It does say organic but that's meaningless as the active agent it Patio Magic is also an "organic" chemical.
I found a reference to Algon at www.mursattchemicals.com/pdf/algon.pdf and it is also toxic to aquatic life. Might not be the same material but I prefer to check the datasheets whenever possible. Usually quite interesting.
Patio Magic came to my mind as soon as I read the post. I use it every couple of years and passed the tip on last year. Greenest, slimiest deck I'd ever seen and owner didn't believe he didn't need to scrub off the Patio Magic. He returned around 2 weeks later and confirmed that it had worked as promised.
I expect Algon will work as well if it is the one based on the chemicals listed in the datasheet.
I'm always a bit suspicious when datasheets aren't readily available. The one you found is, I believe, a different "Algon". I think the Algon referred to in this thread is the stuff on this datasheet - http://www.google.co.uk/url?sa=t&rc...oKFinjp9eC7HuhQ&bvm=bv.42965579,d.d2k&cad=rjt
It looks like it's basically acetic acid (also called ethanoic acid). It's what you find in vinegar. But it is harmful to vegetation and fish, so not quite as benign as suggested.
Patio magic use on my sprayhood and cockpit cover has not affected the waterproofing of the material.
Actually, the base material is widely available in 5 litre packs. Comparing prices, a 5 litre container of Patio Magic, which is a 7.5% solution of Benzalkonium Chloride, costs £17.99. Buying the base material from a chemical supplier, who will happily sell to the public, costs £14.50, and it's a 50% solution - so Patio Magic is more than 7 times the price!You don't need a lot, 5 litres further diluted up to x9 will last you many years. Buying the base material will probably involve minimum 25 kg size, if they would sell to a private person.
Have you ever tried? You may be pleasantly surprised, and save a lot of money!Just reading the back of my tomato ketchup, I could buy the ingredient and make that myself.
