oakleyb
Which is best ? I have 2 banks, starter and 2 x 115 domestic and a 125amp alt. I'm leaning towards the VSR
VSR has lower voltage loss meaning more goes into your battery. Fit it!
VSR is much easier to fit as it doesn't involve soldering wires into your alternator.
Also has a reasonably high cut out so will prevent the 'donor' batteries discharging (unlike a diode block).
And i would make sure it a "dual sensing" type, so it works when charging the domestic bank via a mains chargerVSR has lower voltage loss meaning more goes into your battery. Fit it!
we also have a Wind gen wired into the domestic bank, others may have a PV panel, hence the dual sensingSome Mains Chargers come with blocking already built in. Our Sterling charger is permanently connected to the battery banks and doesn't need to go through any split charging system. Its got several outputs and for a two bank system you tie the majority together and connect to the domestic batteries. The engine start battery gets a nominal single charge outlet as its never really discharged to any great extent.
My Aerogen is direst to the batteries with a control circuit & dump resistor again direct to the dom battsI've got a wind generator in as well. It goes through its own blocking/sensing circuit straight to the batteries. The wind generator regulator is also wired ready for PV panels.
Pete, sorry misquoted, didn't finish the sentence 'if not fitted correctly'. I've see split charging diodes fitted in many ways, if correct and the alternator supply is taken directly to the input and each output goes to each bank it is correct that both banks are isolated. The main problem with ALL of the solid state splitters is heat dissipation and the voltage drop varies depending on the current draw (internal resistance is reasonably fixed) so the power has to dissipate somehow., the 0.6 is approx the minimum it would be, depending on the current the drop could in excess of one volt. The VSR, particularly the dual sensing relays, give you the flexibility that 'any' charging through engines, mains chargers etc are balanced so if any one of the methods are being used the charge can get to any of the banks serviced by the VSR. I've used them for years and never had any battery problems. Ironically, I've just realised, not on the current boat. Need to do something about that.Some alternators come with battery sensing already provided via a terminal on the back. Sometimes there's a short link between this terminal and the positive, to make it machine-sensed by default but with the option of battery-sensed if you replace the link with a wire to the battery.
Can you elaborate on this? I don't have any experience with diode splitters but I don't understand why they wouldn't "prevent the 'donor' batteries discharging" - surely that's the whole point of them?
Where I would say the opposite it the case, you need to inhibit it when using a dual or multiple mains chargers.And i would make sure it a "dual sensing" type, so it works when charging the domestic bank via a mains charger
Mm - I have quite a fancy charger that can be programmed separately for starter and service banks with different chemistry and capacities. Which facility is completely pointless in my installation since as soon as it fires up the SmartBank parallels the two banks anyway
Ariam doesn't spend much time plugged into the mains, so I haven't bothered doing anything about it. Definitely sub-optimal, though.
