pvb
Why do you believe there are two starter batteries.
I don't (see post #31); it was Halcyon who suggested there are 2 starter batteries (see post #32).
I got the impression that you were more interested in pushing VARs to a wider audience .
However if I had been starting from scratch to totally revamp the system then perhaps I would have followed your suggestions but it would be a lot of work as I would have ripped everything out rerouted and removed redundant cable etc
In my 45 years experience revamps never end up totally satisfactory
The first thing is do you have a system that does not work ?
The second question is what do you want to acheive ?
Brian
Yes totally agree and apart from guessing a rating as the Motorolla Ek 300 diode is no longer available it would still be there as a back up to the sterling regulator however would like to get rid of power loss across diodes now that there is a bit of kit on the market with which I could do a direct substitution
With you now on the compensating diode and Sterling regulator .. I think
Pro Split R looks like it would suit your system but if you already have the diode splitter. Isn't the simplest thing to just replace the compensating diode with a suitably rated one from an electronics component suppliers .
