tonyart
Hi, I now have my boat packed up for winter. Although she has been on the water a couple of times, and with new timbers and ply marine sheeting. I now have 2 joint splits in the hull. 1st one is on the bottom of the transorm that joins onto the main V structure timber. This joint is leaking and is letting water through. Only noticed as boat had water inside and had it tipped up to keep the water at the back so I could bail it out, and saw it running out though the crack. Also a 2nd crack along the side of the hull, quite a long crack where the ply boards meet.
What is now the.best way to fix? Sand down the paint to bare wood re seal and paint? And seal from inside as well?
Also what would be the best sealer to use? It would need to beable to move with the timbers so would need tome elasticisity to it
