Splicing old Rope
Stemar
12 Sep 2001
One of my mooring lines was quite badly chafed, so I've cut the damaged bit off and am splicing a new eye, but it's fighting me. It's laid line about 18mm diameter, and feels like polyester, but can't be sure. I've go three tucks in, but I can hardly get a fid in to open up the lay. Apart from the difficulty splicing, while it's far from new, it seems in decent condition
Is there a way to make splicing easier easier?
Untwist the rope back to where you will make the splice, and re-lay it. gives a softer eye though. Should be OK.
Almost impossible to do it with Octoplait though.
I had some 22mm diameter nylon like that for my mooring. The rope even though little used and looking nearly new had gone 'hard'. The splicing took a long time and looked a mess but it has survived a few storms since I did it so the mooring is OK for quite a few years.
Nylon will go hard and is virtually impossible to splice after a year or so. Polyester should last nearly for ever without going hard. I've just changed my anchor chain and re-spliced the polyester tail without issue. Make sure it's clean, and maybe add a bit of fabric softener to the rinse water?
I've had nylon ropes go hard on me before, and this isn't like that, which is what makes me think it's polyester, though I wouldn't bet the cost of a new line on it!
Thanks for the suggestions; I've got three tucks in, so I hope I don't have to unlay it, I'll try the hammer - my kind of solution! - and a soak in washing up liquid and fabric softener.
A very big fid helps! When splicing spectacularly hard-laid rope, I used an iron wire-splicing fid about a foot long to open the strands. The advantage of a wire-splicing fid is that they have a screwdriver kind of end, rather than a point, which makes it easier to get between the strands. A Swedish Fid is no use in this situation; you'll just bend it!
