zoidberg
Gas is perfectly safe if it's properly installed and maintained.
That's a bold statement - a 'declaration of faith' and not of reality. The clear fact that gas can and DOES explode on boats is irrefutable evidence that 'perfectly' is wrong. It is 'conditionally' safe, IF and only IF there are no leaks - hidden or otherwise. IF there are, then explosion is a realand likely result.... and the RYA published a warning video showing exactly that, starring RYA Training Manager James Stevens.
No-one can guarantee 'properly installed and maintained'. No-one carries out a 'Gas Safe' inspection before every sailing trip. No-one can prevent burning gas being blown out briefly by the wind and then accumulating in dribbles in the bilge. At least one of those 'experienced and competent' sorts who gave reply #17 a thumbs-up has skippered a Services boat with responsibility for the others on board - as have I - where a gas explosion blew the stern off and with it the skipper's leg. There were plenty of safety systems there, including a long list of competent and cautious individuals in charge. Wasn't enough.
I've sailed on several boats where the gas system was inadequate - corroded regulator, cracks in flexible supply pipe, blocked gas locker leaking inboard, even one where a gas alarm sounded every time the electrics were switched on until the owner disconnected the alarm....
Gas is usually sufficiently safe for use - but sometimes it isn't. The consequences can be lethal.
