KAM
Has anyone found a supplier of ready anodised aluminium tubing suitable for making spinnaker poles. Something around 60mm. Not having much luck. Nearest I can find is black anodised scaffold pole.
Try a firm who actually do the anodising,Has anyone found a supplier of ready anodised aluminium tubing suitable for making spinnaker poles. Something around 60mm. Not having much luck. Nearest I can find is black anodised scaffold pole.
Selden supplies tubing. But aluminium? Surely carbon fibre is the way to go!
If the tube is a bit too large for the end fittings it is quite easy to cut, say 2" lengths off the end of the tube then cut them to make C shims for the end fittings.But who produces carbon tubes? I have end fittings from aluminium poles.
That is Ok but the tube corrodes from the inside out if only painted.Alternatively, look at Aluminium Warehouse for plain tube and find an anodiser?
Alternative 2, paint the tube instead of anodising? Epoxy? palstic coating?
Svb24Has anyone found a supplier of ready anodised aluminium tubing suitable for making spinnaker poles. Something around 60mm. Not having much luck. Nearest I can find is black anodised scaffold pole.
