D
Deleted member 36384
Hello,
I will be buying new genoa sheets and want to take the opportunity to improve the method for attaching to the sail. Currently use bowlines but the knot catches on the inner forestay. I am thinking that one long genoa sheet, cow hitched through the clew of the furling genoa will provide the smoothest transition. Alternatively, I could have each sheet supplied with a spliced eyelet and use a rope / soft shackle, but I have never used a soft shackle, so not sure how secure it is when flapping about, or just attach the sheet by feeding the end through the loop. The sheets will be 14mm. What do you think is the best method for the smoothest transition to avoid catching on the inner forestay?
Thanks,
BlowingOldBoots
Thanks,
BlowingOldBoots
