RichardS
N/A
Single cylinder 420cc Honda clone
Ah ..... I can now understand why the problem arose in the first place.
Richard
To be fair Richard I’ve had dozens of cheap engines on chainsaws, strimmers, lawnmowers etc. Never had this problem Even the “famous name” ones are probably just badged and from the same factory in ChinaAh ..... I can now understand why the problem arose in the first place.
Richard
Yes but you didn’t say howUnfortunately threadlock is destroyed by heat and will not lock an insert in place. Some mechanical method is needed, as I said in my earlier post.
I think I would have bought a new head and be done with it.£35? What kind of engine are we talking about?
Richard
I have a B&Q supplied Hyundai strimmer, actually very good. But I have seen exactly the same with two other names on them.At that price it's something of a no-brainer, even for a bodge-merchant like me.![]()
However, I'm surprised that it's that price as it's a Hyundai rather than a cheap no-name Chinese as I suspected. Hyundai are generally a reasonable quality brand.
Richard
Financially yes. Time wise no. I need this beast working today. Hyundai have confirmed price at £26 plus vat so new head will be longer term solution yesI think I would have bought a new head and be done with it.
In the olden days, Triumph main dealer plenty of grease on the tap to collect the swarf was all that we did!Not strictly boaty, but easily could be and I value the advice of other forumites.
I started to remove the spark plug from a (4 stroke) engine today and initially all was normal. Then it started to bind. I couldnt really work out what was happening as it couldnt be a crossed thread (having gone in by hand easily a few weeks ago). I tried to screw it back in and then out again but nothing helped. Eventually I could see no option but to use more force.
So out it came - the last three threads of the plug (i.e. the part deepest into the cylinder) are clogged with alloy - so badly that I cannot clean it out of the threads.
The equivalent part of the cylinder head threads are stripped. i.e the three or four threads nearest the top of the hole.
Thread spalling seems to be the issue and I know this has long been an issue for sailors with stainless screws in aluminium and alloy boat parts.
Anyway, we are where we are - when i repair it I will use some form of anti seize compound. I will make a reapir with a helicoil type kit, reaming out the hole, cutting a new thread and putting in an insert.
My question is this. Having researched the use of these thread inserts some people say dont worry about the small alloy chips going into the cylinder as they will be blown out or melt as soon as the engine is started. I'm not entirely convinced.
I will try to stop as much swarf as I can by greasing the tapping tool but some is bound to get in.
I dont think blowing out the cylinder with air is any guarantee either.
The 'perfect' answer is to take off the head, but its a brand new engine just a month old, so I am reluctant to do that with all the dismantling that will be required.
Has anyone done this sort of job before, and if so how did you deal with the swarf issue?
