Spare gas cylinder storage
MikeBz
22 Aug 2005
East Anglia
Our boat currently has a drained locker which holds exactly one cylinder. Is there a risk of a 'fresh unopened' cylinder leaking, i.e. if we decide to carry a spare is it important that it too is in a drained locker?
Mike
Yes! Also in case of fire, heaven forbid, it is a bomb so if not in the locker store in the open, preferably at the transom.
I once had a Gaz cylinder in my workshop that was slowly leaking through the ball valve. It taught me that if I have one on the boat it must either be in a locker with an overboard drain or on deck outside the cockpit.
If you haven't room in your gas locker have you considered building a vented deck box for it. I saw one on a SCOD up by the mast that didn't look too obtrusive, or maybe there is room on the after deck. Something like this only smaller
According to my surveyor the rules for the spare are the same as those for the live cylinder.
I have had 2 cages made that hang on the pushpit - have to make sure the regulator remains dry.
I have recently thought about our system, the bottles are in a locker in the deep cockpit but the drains are under water so surely the gas would not drain if there was a leak?
If you have space in your chain locker and that locker drains overboard, that is the place to stow your spare bottle. Put it in a heavy plastic bag to reduce corrosion possibilities. It doesn't take a second to heave out on deck when you want to anchor.
The gas is heavier than air and has a bad egg smell added so you should smell it if you are low enough or soon after you open the forward hatch.
You are sitting a bomb, fix it before it blows, also bear in mind the insurance company will not pay out if the installation is not correct, including a separate shut off valve next to the stove.
Avagoodweekend......
Drains underwater = No drains = Chocolate teapot .......
. . . ours is only a chocolate teapot when under way at speed on an even keel or on starboard tack . . .
What would be helpful would be a foolproof gas detetor that will work in a deep bilge without going off if it gets wet . . . our gas detector is under the cooker, but the bilge is 3ft deeper.
So glad I read this! Like the muppet I am I have left two spare gas cylinders in the cockpit thinking they were safe because its "Self Draining"
Ah well, what doesn't kill you makes you stronger - but it doesn't do too much for the old self esteem! /forums/images/graemlins/frown.gif
If I had a leak would the butane or propane dissolve in the seawater or would it just sit there in a column in the cockpit drains?
We keep ours in the chain locker. Made a plywood base with hooks to fix bungee cord over top of cylinder to hold in place. Base fixed with sikaflex.
Also made a similar holder for 5 litre petrol can for outboard fuel.
Happy to send pics if you pm me with an e-mail address (haven't yet sussed how to attach image to post!)
